メインコンテンツにスキップ
Sennheiser HD 4.50 Battery Replacement
必要な工具と部品
  1. Sennheiser HD 4.50 Battery Replacement, Battery: 手順 1、 1の画像 1
    • Locate the side designation on the headband-earpiece junction.
    • The battery is on the left side.
    • The motherboard is on the right side.
  2. Sennheiser HD 4.50 Battery Replacement: 手順 2、 3の画像 1 Sennheiser HD 4.50 Battery Replacement: 手順 2、 3の画像 2 Sennheiser HD 4.50 Battery Replacement: 手順 2、 3の画像 3
  3. Sennheiser HD 4.50 Battery Replacement: 手順 3、 3の画像 1 Sennheiser HD 4.50 Battery Replacement: 手順 3、 3の画像 2 Sennheiser HD 4.50 Battery Replacement: 手順 3、 3の画像 3
    • Use a Phillips #00 screwdriver to remove the four 10 mm screws holding the ear cup cover in place.
    • Use an opening tool to pry open the cover.
    • Remove the cover.
  4. Sennheiser HD 4.50 Battery Replacement: 手順 4、 1の画像 1
    • Use a spudger to pry the battery from the plastic case.
    • The battery is held down by a strong adhesive, so it will give resistance.
  5. Sennheiser HD 4.50 Battery Replacement: 手順 5、 1の画像 1
    • Using tweezers, pull the white battery connector upwards out of its socket.
    • Remove the battery.
終わりに
7 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Grace Singley
メンバー登録日: 02/19/21
595 ポイント
5のガイドは作成済み
チーム
University of Alabama, Team S2-G1, Bedsole Spring 2021 University of Alabama, Team S2-G1, Bedsole Spring 2021人のメンバー
UA-BEDSOLE-S21S2G1
4 メンバー
16のガイドは作成済み
6 件のコメント
Hello ! Thanks for the tuto. Do you know where to buy the battery ?
Fren6 - 返信
You can search with the part number(Shown in the photo) : AHB622540N1/AHB622540N01.
Santanu Ghosal - 返信
Where i can find it
Erik Ridwan -
Does anyone know if I can use the he 450 bt replacement battery in a 350 bt headphone? The difference in the spec is that the 450’s battery has a longer battery life (2.2 wh vs. 1.3 wh)
M Lawson - 返信
This was pretty straightforward, but in opening the cap one of the tiny soldered wires pulled off the pad. It's so tiny that I don't have much hope of soldering it back. Any other way to reattach it? I put it back together anyways and now the right cup works fine, but the left is dead. I recommend a warning here about the little wires, if nothing else.
David Hook - 返信
コメントを追加
統計データ:
過去 24時間: 27
過去 7 日: 152
過去 30 日: 587
今までの合計 12,664
