How to fix broken spring for - side of battery?
The spring for the - side of the battery on the Wii remote is broken. How to fix it?
Is it snapped off or is it corroded? If its corroded, use this guide to help you fix that.
Nintendo Wii Remote Disassembly and Corrosion Cleaning
If the metal piece itself is broken or the cleaning doesn't work, you can use these replacement contacts and take out the bad ones.
Nintendo Wii Controller Battery Contacts Genuine Replacement Part - JAPAN
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 16
今までの合計 549
