メインコンテンツにスキップ
2018年9月21日に発売されました。モデル番号A2097, A2098、GSM もしくはCDMA / eSIM もしくはナノSIM / 64, 256、512 GB / シルバー、ゴールド、スペースグレイ。(正しい発音は"iPhone 10 S.")
402回答 すべてを表示
iPhone XS turns it self on after water damage
I dropped my iPhone XS into a pool by accident
i did hard power off but phone powers it self on I let the phone dry a few days
now the screen won’t detect fingerprints swipes nothing at all it’s stuck on Lock Screen
The iPhone XS battery is almost empty
I do have a new screen and battery I do have a True Tone programmer but not sure if that will fix the issue
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi @totallya
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a the ifixit iPhone XS guide that may help
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
I dry the inside changed the screen and the battery I couldn’t get True Tone data I guess the water damage did that
さんによる
@totallya some cheaper screens won’t accept true tone as the ‘chip’ won’t accept the data. To be on the safe side I’d find a mobile repair shop and ask them if they have an ultra sonic cleaner they can put the board in to clean it properly. The board is a sandwich board which means you can clean the external sides of the board but not the internals. Liquid could still be inside causing corrosion.
さんによる
@strongbow
the original OEM screen was underwater do you think an ultra sonic cleaner works?
さんによる
@totallya on the board yes but not the screen. Once the screen has gone it’s gone I’m afraid.
さんによる
コメントを追加
回答を追加する
Ezekiel Serrano さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 57
