メインコンテンツにスキップ
小さめのアップルMacBook Airラップトップはデュアルマイクと802.11ac Wi-Fi接続を特徴としています。
149回答 すべてを表示
Tips to remove MacBook Air A1495 hinge plastic?
I tried to remove the hinge plastic on my A1495, so I can tighten the screws under the plastic, but with my metal pliers it would not want to come off when I tried prying from the left. Eventually, after using enough force, it just cracked from about 1/6th the way in (as shown in the picture below)
I am unsure what I did wrong, it just would not move after a certain point, and the very few tutorials showing this didn't show what to try if that happens.
Thankfully, no actual hardware was yet broken so I can just buy a new hinge plastic from eBay.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Apple loves making this harder then they need to be to make the system repairable! So we often need to take other things off to get to the part, which is the case here! Here’s the guide to take the display off MacBook Air 11インチ Mid 2013のディスプレイアセンブリの交換
Now with the display in front of you it’s now possible to slide the clutch cover off sliding it slightly to the side so the catches clear into the slots, then pulling downwards.
Maybe it would help getting the replacement to see things MacBook Air 11" Clutch Cover (13-15)
But… I think you damaged the antenna unit as well here MacBook Air 11" Hinge - Left/w iSight Cable & Antenna
このアンサーは役に立ちましたか?
スコア 0
6 件のコメント:
I had tried removing the whole panel earlier (which some tutorials say is not required) but it made no difference. It wouldn't slide neither
さんによる
@piipperi - I would get the needed parts as once you have it you can see clearly how this Chinese torture puzzle works 🤬
さんによる
My point is I dont want to break the whole display. I have already ordered the part. I'm afraid if I brute force it I'll destroy the display cables
さんによる
@piipperi - I’ve done quite a few both Airs & Pro’s and they can be tough! Some repairs I’ve had to use a knife as someone glued it on!
All I use if not glued, is a rubber grip to grasp the edge, not too tightly as the pressure will tighten its grip to the lip, I also push inward a bit.
Now you can see it’s a bit of a Chinese torture puzzle as it’s a bit of balance of pressure so it’s doesn’t bind
さんによる
@danj ok I see, so just kinda brute force it.
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Piipperi800 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 19
今までの合計 153
