The selected device could not be found error on finder and itunes.
It is a 80gb iPod 5.5 gen with fat32 format. It was working prior to adding 2 songs after my mac glitched I force ejected it and now this is happening please help.
Hi
Have you tried wiping it using disk utility/disk manager?
When I get these sorts of errors that usually fixes it
If not try reseating the battery and hdd connections
Here’s a guide for that
Hopefully this helps
Any questions please ask
ガイド
難易度:
中レベル
20 minutes
ガイド
難易度:
中レベル
30 - 50 minutes
このアンサーは役に立ちましたか?
Disk utility was having a rough time loading disks and it couldn't see my iPod, I don't have tools to open the device and the hard drive has a loud high pitched noise and it clicks plus it has 12 pending sectors and 146 reallocs would that be the problem?
Hi
Just from telling from the noise that it makes that is most likely the issue
To add to that 12 pending sectors is quite a lot so replacing the HDD is probably the fix and of that doesn’t work ether a battery or a Logic board
過去 24時間: 0
過去 7 日: 9
過去 30 日: 21
今までの合計 318
