メインコンテンツにスキップ
Samsung Galaxy Noteシリーズの第三世代ファブレットです。2013年9月25日に発売されました。モデル番号はN9005です。
Strange screen issue depending on the brightness
Hi.
I just bought a Galaxy Note 3, and seems to have an issue, basically, if the brightness is not on max, it shows this strange static on the screen.
Sometimes it doesn't show, but that seems to be rare.
Could this be a flex cable issue?
Thanks
Update 12/28/2022
Unfortunately, the screen is all black now, it started as a few purple spots to a completely non-functional screen.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @overflowunt
It may be a display problem.
Does it do this when the charger is connected?
Try using the phone in safe mode and check if the problem occurs.
If it doesn't then a downloaded app may be the cause of the problem. The trick is to find out which one.
Also try mirroring the screen and check the display on the external display. If it is OK then it seems like the problem is related to the display.
Here's the ifixit Samsung Galaxy Note 3 Display Assembly Replacement guide that may help.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
I installed a custom ROM and it still shows, I'll try to mirror the display and see if it shows on the external display or not.
さんによる
If you say it’s rare which I’d take as intermittent then I’d take the back off and check the cables for the screen etc are all seated correctly.
さんによる
I tried recording and using TeamViewer and it doesn't show on any of them.
I opened the phone and I may be wrong but are these (they look like resistors?) on the board burned?
https://snipboard.io/RX0din.jpg
I tried cleaning with etylic alcohol but it didn't help.
The phone screen also appears to have this yellow spot at the edge.
https://snipboard.io/3WukC2.jpg
さんによる
コメントを追加
回答を追加する
OverFlowUnT さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 14
今までの合計 169
