メインコンテンツにスキップ
2020年にAppleより発売されたトップラインのスマートフォンです。iPhone 12 Pro Maxは11月13日に発売されました。6.7インチ OLEDディスプレイとLiDARを搭載したトリプルリアカメラシステム、5Gネットワーク接続が可能です。iPhone 11 Pro Maxの継続モデルです。
89回答 すべてを表示
Is my iPhone 12 toasted? Or still repairable?
Hey, I am on vacation and my iPhone 12 max pro slipped Into the pool. It was in 2 feet deep water and 5 minutes max. I thought the 12 max pro was supposed to be water resistant for up to 30mins but somehow this caused condensation to build up in the 2 left cameras and front camera. initially this causes Face ID to turn off and it later experienced problems with the sim. I’m using e-sim outside of the US, so for some reason this wasn’t connecting to the local network provider. Then these problems seem to fixed itself but lock button starting experiencing problems. It kept locking itself and holding on until it dialed sos. (Took me many tries to finally beat it the setting menu and disable auto-sos dialing).
It’s day 2. Phone was working except still problem with lock button. I tried turning phone off but because lock button issue, it kept turning back on (no, the lock button is not depressed or stuck). I found some desiccate package from local snacks and I tried wrapping the phone in a small bag with the desiccate package.
Day 3: battery finally died. When charged - Lock button won’t work (so I can’t turn on) and my phone is now showing “plug into laptop to restore” symbol. I was seeing this on day 2, but sometimes it would load up to Home Screen where I can unlock and use phone for a little bit. Now I don’t even see that and I’m worried.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi @ivyc,
Liquid damage is tricky for phones. Given the quantity of chemicals used in pools, the chance for contamination to affect the electronics in your phone is pretty high.
So the first thing is, the sooner you get it taken care of, the better. The longer those chemicals and liquid are allowed to sit in the phone, the more chance of irreparable damage there is. Given that you're already experiencing problems, you need to do this now.
For now, turn off the phone and don't try to charge it. Forget putting it in rice; that doesn't work. Leave it out where air can circulate and it can dry.
If you're comfortable disassembling your phone yourself, you can use the guides available on this site to take everything apart and clean it all. It's a big job with lots of opportunities to break things, so if you're not confident in your abilities, then don't. The guides can be found here.
iPhone 12 Pro Max Repair - iFixit
And a guide for liquid damage mitigation is here.
iPhone Liquid Damage Repair - iFixit Repair Guide
Otherwise, you'll need to locate a repair store that specializes in liquid damage and get the phone to them ASAP. Your phone may be repairable, but the longer you wait the less your chances of getting back a working phone are.
Good luck; let us know how it goes!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Staby_staby@hotmail.com さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 15
今までの合計 57
