メインコンテンツにスキップ
2015年1月発売。XPS 13ラップトップは”見た目はボーダレスなインフィニティディスプレイ”を搭載し、タッチスクリーンへアップグレード可能な、MacBook Airと対抗するべく開発されました。
20回答 すべてを表示
Battery status idle, not charging after calibration
Hi, I bought an Ifixit battery replacement for dell xps 13, replacement went well, first test successful, battery was charging with 130Wh AC adapter.
After recommended battery calibration, full charge and complete discharge by the computer, the battery is not charging anymore.
bios tells battery charging status: idle, health status: excellent, no power is transferred to the battery
I am left with 2% battery life in the new one.
Switching ac adaptor does not help.
I put in the old battery again, which is charging with the mentioned 130Wh adaptor, but doesn’t hold capacity….
Is there a known solution for this situation?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
I have the same problem.
After fully changing and draining the battery, it now stays at 0% charge. (It was supposed to turn of at 5%)
Dell diagnosis say the charger and battery are fine, health is excellent.
Any recommendations?
さんによる
Changing the CMOS battery would have reset everything so your only option I guess is IFIXIT Contact Customer Support.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Updating the BIOS and drivers may help:
https://www.dell.com/support/home/en-nz/...
Diagnostics could be run from
Did you use this method to recalibrate?
https://help.ifixit.com/article/265-batt...
Are you sure the charger is the correct one for the DELL laptop?
Maybe you missed a step in the calibration? Perhaps try it again?
That system is about 7 years old. Have you replaced the CMOS battery recently?
Dell XPS 13 Display Assembly Replacement
Far right centre in photo. Black and red wires to coin battery enclosed in black heat shrink plastic.
(Repeating myself here) You could run the Dell Dignostics ( number 12 in list & 15 reset BIOS to default):
https://www.dell.com/support/kbdoc/en-nz...
Also you could look in the Service Manual pdf:
Let us know how it goes.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Tried all recommended actions, no change at all, ifixit replacement battery is not charging
さんによる
Hi@benbretsch92610
さんによる
コメントを追加
回答を追加する
Ben Bretschneider さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 26
今までの合計 1,695
