メインコンテンツにスキップ
The first generation of the Chevrolet Equinox, a crossover SUV from Chevrolet based on General Motors' Theta platform.
114回答 すべてを表示
anti lock brakes and traction control lights on
I constantly feel and hear a pulse when breaking. Lights for the antilock brakes and traction control are always on on the dash. Maybe traction control is on all the time? Maybe the antilock brakes are always working? I'm not sure which. How do I fix this?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 40
29 件のコメント
can the tcs cause you vehical not to start
さんによる
will the traction control shut down the engine.
さんによる
it will not shut the engine down but it can cause power loss and no acceleration
さんによる
Well im having problems with my back brakes sticking and releasing sometimes. Its light something holding my speed back wile drivin down the road. What can no of part I need to fix this problem
さんによる
I just replaced the front passenger bearing because my bearing was shot and my abs n tc (traction control) light was on it went off after I replaced my bearing about 3 days after the abs and tc icon light came back on so I checked the abs wire behind the tire connected to the hub bc in my case it's a sealed unit. The wires looked good and were connected I turn the car on and off and the icons go away shortly after the icons the icons come on again constantly. Any suggestions
さんによる
24件以上のコメントを表示
コメントを追加
17件の回答
ベストアンサー
If the traction control light illuminates and stays lit without blinking, this means that the traction control system has been deactivated and there is no traction control available. The only way to find out what is going on with it, is to get it properly diagnosed. I would go to my local GM garage and have them do a, analyzer check to determine what error codes you get.
このアンサーは役に立ちましたか?
スコア 13
5 件のコメント:
I had pulsing breaks and an ABS light on, found 6 plugs(4 front, 2 back) to spray with contact cleaner and no help. Finally the last plug fixed the problem. Next time I will add grease to this plug. It has 4 wires on the plug, it is under the car in the center between the rear tires. This really did the trick!!
さんによる
Ok I have a 2009 Chevy Malibu my friend had a diagnostic machine it sad lost communication with ECM and pcm on da messages it said tration of stability antilock brake system my car will come on but will no crank just a clicking noises sound like it coming from da passenger r under consultant by gear shift please I need help to solve dis problem hg as d change my break dat dey just bought da car da breaks was scrubbing so bad wen u off dat break it was still making a bad sound break were gone change da break later on turn car off tried to crank back up all light come on no start no crank it tine to start but wen I try to crank and and all other light on dash bored. Goes off da machine I hat sent a code au100 r something like dat ou100
さんによる
what is the locations of the six plugs... are they all under the car ??? please give locations thanks
さんによる
leetompkins which plugs are you talking about
さんによる
@leetompkins What I have came to realize is when these lights come on, its normally something else that is the problem so the suspension should be checked that nothing is loose or wobbling or could be bushings. Yet you have pulsating brakes so maybe its your rotors that need to be replaced
さんによる
コメントを追加
MUST READ FOR EQUINOX ABS SENSOR ISSUES
Most mechanics do not think this far a head as the problem can be caused multiple things.
The most common is the wheel bearings wear out causing the break sensor to touch the hub causing the sensor to error out.
If it happens to one bearing the rest are going to be bad soon. So fix them all.
The good thing is the fix is relatively easy. The bad thing is the parts are a little pricey.
You'll have to replace all the wheel hubs to fix the problem.
Here is another part that also requires attention and repairs to fix the ABS errors. If any of the other parts in the suspension are worn it will affect the rotation of the wheel and sensors, mostly when breaking. Example: if the front struts are worn out or have lost the gas charge the wheel will have some "chatter" when breaking. It may not be noticeable to the driver or you may not feel it in the steering wheel. However, the wheel sensor picks this up as loss of traction. So, if you replaced the hubs and you are still having the same issue, replacing the struts along with the wheel hub could fix the problem. Have your mechanic look at the rest of the suspension parts to ensure there are not any issues.
Another benefit to repairing the worn suspension parts is your vehicle will drive nicer and will be much safer to drive.
As you were told when you were a kid, "pay attention".
このアンサーは役に立ちましたか?
スコア 8
1件のコメント:
This happened to my 2005 equinox but when the stabiliter service light came on i had no power steering so what does that have to do with the wheel bearing going bad I've had wheel bearing go out before never has it effected the power steering
さんによる
コメントを追加
I've encountered this before on my old Jetta as well as some of my friends' cars. Both of these systems work using a signal from wheel speed sensors that are generally mounted on or near the brakes. They're usually about the size of a roll of pennies. If they're gooped up, bent out of alignment, unplugged or the wires are damaged they will send a "no-spin" signal to the computer, telling it to activate the ABS (that pulsing you're feeling in the brake pedal) as well as cause all sorts of errors in the traction control module. That seems to be the most likely source of failure.
If you determine that one or more of the sensors are faulty, check your local auto parts store for replacements or rockauto.com. The dealer should be your last resort buying parts since they mark up their parts 100-500%.
Fixing the sensor(s) may not make the lights go away. You'll have to take it to an authorized GM repair shop or dealer to have them reset the computer modules for the ABS and TC.
OR, if you're feeling wealthy, you can buy one of those nifty gadgets yourself, but be warned: the ones that can access ALL the computer's modules cost $$$$$$$$$$ (those $200 OBD-II units at your local auto parts store can only access the engine module) and require you to get a hold of some good factory literature so that you don't change a setting that will break your car even further. Best of luck!
このアンサーは役に立ちましたか?
スコア 7
3 件のコメント:
My mechanic said that it was the A B S. Oil pump I have contaminated my brake fluid
さんによる
Well dose that make sense to anyone else??
さんによる
yes i just changed the front pads out on a 2014 impala when i forced the caliper pistons back and the fluid was pushed into the master, everything that was in it was clean, however, after the fluid reached the master, the fluid was swirling against one another. I will have to go back to the basics and flush the system by bleeding the whole system until the fluid runs clean and hope that does the trick
さんによる
コメントを追加
Buy a gm part #22715444 replace it it will fix the problem
このアンサーは役に立ちましたか?
スコア 4
4 件のコメント:
Bigfndiesel is exactly correct. I bought the part he suggested 22715444..problem solved! Like 50 bucks. Thank you so much!!!!!
さんによる
I purchased the abs wheel sensor harness for both front driver and passenger side on Amazon.com for less than $40. My husband changed out the old one and lights are no longer on. Now all we need to deal with is the airbag lights staying on. Anyone have a solution to the airbag light being on?
さんによる
the air bag light was part of the giant recall last year, give the dealer the vin number and they can tell you for sure..the ignition switch was the problem with a lot of them
さんによる
The problem is contamination in the W/H CONNECTORS FROM DERBIES. In earlier models that first had ABS brakes the sensor was part of the wire-harness assembly(all sealed) was apx 2-4 feet long NEVER HAD A PROBLEM as the only connector was in the engine compartment above all the mud/ etc on the fender . Now there are four connects on the front underneath car and two in the rear underneath car... ITS NO WONDER There is a constant problem. THIS DESIGN IN UNRELIABLE AND CUSTOMERS WASTE MILLIONS OF DOLLARS ON THIS UGH..poor product design
さんによる
コメントを追加
There are so many possible answers for this question but the old turkey said it best get the codes read at your dealer and find out exactly whats wrong . If you happen to have access to a reader that does abs that will go a long way to helping you out but until then your only guessing. Ive replaced abs pumps with cars that have a traction control light on and Ive replaced sway bars as well changed wheel bearings abs sensors. brake pedal sensors and drive by wire gas pedal all for the same light. In some cars its the gyro that tell you when the car is leaning that screws up. Getting the codes read is your best option
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
I got the codes read and replaced the wheel sensor but it did nothing to fix the problem
さんによる
コメントを追加
My 07 equinox right front break caliber kept locking up. Replaced the guide pins, replaced the abs speed sensor and rebuilt the caliper with no results. The brake continued to lock up and the service stabilitrak / traction control kept coming on. I don't know what possessed me to do this, but I put my foot under the brake pedal and pulled up. It released the caliper and knock on wood I haven't had any issues since.
このアンサーは役に立ちましたか?
スコア 3
6 件のコメント:
I have a 07 equinox and the ABS and the TC light comes on says service traction control also service stabilitrak but the car runs fine but sometimes I feel like the car jerks a little as if I tap the brake really quick but again sometimes when I turn my car on it doesn't say anything the ABS light will be on for about 5 seconds then it'll disappear but if I turn off the car then on it'll come back on.....what can be that problem...
さんによる
Wendy, OMG I was literally stuck on the side of the road...my car would not accelerate, and the abs light popped up but went away. I checked my brake fluid, shut the car off for a while, cut it back on, but I still couldn't accelerate unless I pushed the accelerator down all the way to the metal and even then it only moved slightly. My daughter began to cry, I told her to trust God and have patience. Shortly after Googling my issue, I read a few posts and right before I was about to call a tow truck, I read your post and putting my foot underneath the break and lifting up worked right away. I'm now sitting in my car in front of my house and had to take the time out to open this account so I could let you know how grateful I am to have read your post. It's been an extremely long work week for me and I was so looking forward to getting home and relaxing with my family. Today is Friday January 15, 2016. Thank you so much Wendy, you're awesome!
さんによる
That's awesome to hear, Rafeka! If you have the time, you should post that as an iFixit story. I'm sure others in the community would love to hear that!
さんによる
Rafeka, what an amazing story. You should post your story to other community's like Tanner Lange suggested. Others would probably enjoy reading it. I'm glad you found the answer to fix the problem you encountered. Also, I'm happy that you found the courage to Google your issue while sitting on the side of the road, instead of just throwing your hands up and giving up. I see way to much of that these days. I would like to say this one last thing... your actions on that day will not go unnoticed, as your daughter was there to witness your bravery, and courage. Good for you and God bless!
さんによる
I have to comment as well, my 07 equinox is doing the same thing the service track light comes on on my brakes lock up. Put my foot behind the break and released. I gotta take it to the dealer, this is ridiculous
さんによる
1以上のコメントを表示
コメントを追加
Mine was a 2006 Pontiac torrent which is same as the Chevy equinox a mechanic diagnosed as bad brake module. They are very expensive so they suggested eBay. I bought a used one guaranteed to work my mechanic installed it and reset my computer system. It fixed the problem for about a year and then retuned with the same problem I will probably have to replace it again.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Problems with front brakes dragging rotors getting hot - I have fixed over a dozen by spreading the bracket clamped to the rubber part of the brake line - In time the bracket rusts inside pinching the hose so fluid does not return to release the caliper — I hope this helps someone with rotors heating up. THANKS JOE
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I have a Chevy equinox 2006 and last week both ABS and TC warning lights came on. I had no locking pulsing or tremors, in other words the vehicle runs fine. On a whim I checked the tire pressure and sure enough the rear tires were low. After I added air...the lights stayed off( Until today). Once again the lights came on and NO Problems>>>>so i rechecked and added air again...the lights came on shortly after then went off when I restarted the car, only to come on again... Since there are no obvious symptoms like shaking or pulsing I am going to disengage the Black or (-) terminal from the battery to reset the computer. We will see then. Once again...my lights came on without any issues.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
yes proves this is an electrical issue... i will spray clean the contacts of all six wire harnesses BECAUSE THESE CONNECTORS ARE IN A MUD/DEBRIES PRONE AREA ABOVE&BEHIND WHEEL THEY CAN EASILY GET CONTAMINATED if I fail THEN I WILLreplace both abs w/h as my 2005 equinox will throw the T/C LIGHT WITHOUT MOVING USUALLY RIGHT AFTER THE ENGINE WARMS UP... COLDER DAYS TAKES MUCH LONGER BUT CAR DOES NOT NEED TO MOVE PERIOD. SOO NOT LIKELY WHEEL SENSORS
さんによる
コメントを追加
My 2008 Equinox does the same exact thing, it seems like the back right tire locks up, and the traction control light comes on. i took it 2 times to the mechanic they have no clue what the problem is. I keep adding break fluid. But they say no leak. It has no pick up and i cant move the car once the break locks up. It seems like the tires are dragging, i smelled the burning rubber.
I am going to try and put my foot under the break . They also made me fix a sensor . I am so fed up with the car at the moment !!!!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I have a 2005 Chevy equinox and it's doing the same thing it feels like the back breaks are locking up or dragging it will move but my abs and TC lights stay on but after I shut it off and crank it it will drive fine until I hit the breaks and then repeats what I just said it did.. Did you ever find out what could be the problem because I have no clue
さんによる
コメントを追加
I have a 2008 acadia when hit brakes traction control an stabtrack comes on tgen go off .have replace mass air sensor an brake switch need help please
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
I have a 2009 acadia and replaced the left rear wheel sensor which is what the code thing stated wrong. Didnt help anything, when the light is off the abs tries to kick in making an awful noise. When you hit 30 mph the abs and traction control light come on and you hear no noise when braking?!?! Help
さんによる
I have a 2006 Econox Lt.just replaced altanator.but engine light is still on.and today and lights came on and lost all power and won't start now.got a jump start and it started up then it won't move& dies.any suggestions.
さんによる
On 2006 econox lt.engine light is on just replaced altanator on it.engine light still on.abs lights sundenley came on lost all power pulled over shut car off then tried to restart it and no luck.got jump start made it half way home lost all power and wouldn't start or move abs lights and some elctronic weird noise .from someone where
さんによる
On 2006 econox lt.engine light is on just replaced altanator on it.engine light still on.abs lights sundenley came on lost all power pulled over shut car off then tried to restart it and no luck.got jump start made it half way home lost all power and wouldn't start or move abs lights and some elctronic weird noise .from someone where.need advice.
さんによる
コメントを追加
My 2009 Chevy Equinox gave me the traction control error, but no codes, because it is an intermittent problem. The dealer checked the vehicle and called back, reporting that the wheel speed sensor on the left rear wheel (behind the driver) was open. Replacing the sensor fixed the problem. BTW, when I went to pick up my fixed Equinox, a 2009 Pontiac Torrent arrive with the same problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
22715444 part number 50.00 on ebay
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi please I have a 2014 Kia Sportage .. and I have a problem with the turbo but after it was replaced.. but when driving I don't get the full power and the abs and traction control lights pops out and everything on the cluster goes Off without working including the reverse camera and the lights not working..we have checked all the wiring on the car but to no avail ... can any help me please thanks
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have a 2005 equinox lt,and my problem is it cranks fine and take off fine but when i accelerate pass 3rd gear the gas pedal lose engine power and a triangle light with down arrow pop up and speed drop down to 25 mph with foot to floor. But when i stop,light goes off and it drives fine until after the 3rd gear cycle and repeat the fault again. TC light and triangle light pop on. I have real bad hubbearings,can this be the issue of loss power mode kick in?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
hello I have an 08 chevy uplander and my traction control light is also on but to know where it is at in my van can i fix it my self ????
さんによる
コメントを追加
My 2005 sable was going down the road fine I had just got gas my brake light has been on for a long time but soon as I turned I have never had any transmission problems with it or anything like that but when I turn my wheel to the right On the road to go on my way it was like I just threw my car in park Or slammed on brakes all I could do is rush my motor to try to get it to move no gear change I couldn’t move so I somehow got on the side of the road it sounds good never had a problem it’s a fine vehicle it does everything fine but when I try to change the gears it does not go into any gear there’s never been anyOf this I even tried to take the transmission Fuse out to make sure my fuse was working to tell me if my transmission was going out it was fine my fuses also now my car is just sitting there it will crank Sounds goodit does everything fine no kind of noise coming from it it just won’t move or go into any Gear . I really did drive a long time with my brake fluid light showing I don’t know if that’ll affect anything could please someone answer my question because everyone say s the transmission its not the I think trans and I think they’re wanting more cash help
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
might be an obvious one but do your brake lights work, if the fuse blows on some cars the ABS and TRC will disable.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Yes brake lights work but thank you, now light stays on all the time, my mechanic states it is in sensor and will cost to fix so he suggested just leaving it. I will never buy another Chevy this is the worse care I have ever owned in my 50 years driving
さんによる
I have a 2006 econox lt.a.w.d.i had the alternator replaced due to engine light on and it being bad.but engine light is back on.i was driving and all of a sudden abs lights were on every where on dash bored.lost all-powerful.pulled over shut car off.then tried to start it back up but no luck.got a jump start and made it a couple blocks then all lights came on and lost all power and now won't start at all.can anyone help me with what it can be
さんによる
コメントを追加
回答を追加する
chris さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 15
過去 30 日: 75
今までの合計 347,964
