I have Nikon Coolpix S3000.
I get “Lens Error” message, when turning ON, and at the same time, the lens comes out and back in. ?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Had the same issue on my Canon PowerShot s100, it started like that and now the lens is completely stuck in the open position. I haven't fix it yet, but here I found a link to a webpage with very useful tips on how to try solving the "Lens error" issue, the good thing is it applies to virtually any camera manufacturer. Just remember that some of these methods (1-5) are unharmful, while others could damage the camera even more, so proceed in the steps at your own risk.
Good luck with the repair, let us know if you need more advice or if you manage to fix your camera
このアンサーは役に立ちましたか?
website, doesn't exist
このアンサーは役に立ちましたか?
@bryanthoma61055 you are right, luckily a copy of that page is still available here: https://web.archive.org/web/202208032231...
https://www.fixya.com/support/t5512209-n...
Another set of instructions for this issue
過去 24時間: 3
過去 7 日: 24
過去 30 日: 99
今までの合計 1,081
3 件のコメント
Thank you so much for your valuable response. I have tried all the basic tips, but nothing seems to work. The only thing left is to take it apart, for which I need a free time. I shall certainly try to tackle it. Watch this space !
Bhupinder Sandhu さんによる
@bhupy I see, indeed I've been in the same predicament for a while, maybe now I'll start from where I left off and share my experience too, if the repair will be succesful. Anyway I'd say go for it, although this is quite a delicate operation, at the end this could turn out to be caused simply by some trapped debris or by a loose connector; at this link you can find some useful guides that'll help you set up the work space before you start: Electronics Skills.
Of course we'll be happy to hear how it's going or if you've managed to repair the camera, keep us updated
Simone さんによる
Thanks for the encouragement. I need to get those ‘fine tooth and comb’ tools now. Thanks again, Simone..
