Senario Scoozi plush toy - how to open and replace battery?
My Senaio Scoozie pet plush toy has stopped working. Not sure if it's broken or bad battery. Does anyone have tips on how to open it up without seriously damaging it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Ok, so sadly you have to cut it open to replace the batteries, I recommend going along the side of the stomach where it attaches to the fur with a seam ripper, then re-sewing it later with brown fur, maybe attaching a zipper or velcro.
These toys aren't made to replace there batteries, So I recommended installing a small zipper onto the plushie or velcro, that way you can replace its batteries again in the near future without cutting it up again. Here is a link to buy a zipper: https://zipperstop.com/products/ykk-5-mo...
Here is link to buy velcro strips: https://www.homedepot.com/p/VELCRO-Brand...
The batteries are usually 357 button cell batteries, most of the time these toys take 3 and is in a black box that connects to a speaker and circuit board. Sometimes the batteries will explode and corrode in the toy, even if new, that's why I recommend installing a zipper on the side of plush to check batteries from time to time. You should clean corrosion with rubbing alcohol and a q-tip.
I don't know if yours is just a plush or is one that moves its mouth/eyes, if it moves its mouth/eyes it is more complicated and probably takes 3 AA. I do not see any eyelids or mechanism in the face, but Here is a commercial of the one that moves its mouth/eyes: https://youtu.be/ZrpxqNLArTc
I hope this helps!
このアンサーは役に立ちましたか?
Took me a long time to see this reply, but thank you! I'll dig out my seam ripper and get to work. 👍
過去 24時間: 1
過去 7 日: 1
過去 30 日: 13
今までの合計 1,041
