Gps and callspeaker do not work properly after repair
I replaced screen assembly and mid frame of my device but call speaker and gps are not working anymore. Speaker intermittently, gps poor localisation when in use.
Hi kevin bracke,
The first thing I always do, is open the device up again and reseat all connections again. I usually also always clean the connectors with >99% isopropyl alcohol, because it’s always a good idea.
It’s important to always disconnect battery first and then connect the battery again last. Leaving the battery in when disconnecting or connecting other components, very often leads to breaks.
If a clean and reseat doesn’t help, take some good quality, close up pictures and update your question following this guide: Adding images to existing questions. Then we can try a deeper dive into it ;)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 40
