メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2021年4月に発売されたApple社製24インチiMac (M1)の修理ガイドとサポート情報です。
How to fix my slightly cracked screen?
My iMac fell on the floor and is still operating expeditiously but there is a crack that is somewhat visible but not massively visible. It extends from the top left hand corner of my iMac to the center of the computer screen and back down to the right hand bottom corner. Even though the crack covers a large area, the crack did not penetrate the computer and looks like maybe a cat scratched it or a slight laceration to someone's arm.
It is not essential to get this fixed but I would like to if possible. I have tried the eraser method, the Vaseline method, and hand sanitizer. Any ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
Hi
Unfortunately you will need to replace the display assembly as it’s the easiest option and for most people the only option unless you have the equipment to separate the glass and display
Here’s the guide to replace the display
iMac M1 24" Display Austausch
This guide isn’t fully finished but it should get you though the majority of it
If you could find a screen protector or privacy screen for your iMacs display it could help make the crack less noticeable
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
Thank you so much for all your help. Do you know where the best option where be to buy a new display assembly?
さんによる
@Elliot Swincher
Unfortunately because this model is soo new these parts are hard to come by so the only ones I could find are in other currencies
https://www.ebay.co.uk/itm/175443093964?...
This one comes from France but I would ask apple to see how much it is for them to do it for you as it could work out cheeper:-)
さんによる
コメントを追加
回答を追加する
Elliot Swincher さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 15
過去 30 日: 79
今までの合計 6,078
