メインコンテンツにスキップ
2020年8月に発売されたSamsungのビーンズ型Galaxy Buds Liveワイヤレスイヤーバズの解体と修理情報です。
19回答 すべてを表示
Samsung Galaxy Buds Live charging case teardown.
Do you have the techniques and teardown steps on Samsung Galaxy Buds Live charging case? I had mine washed on a washing machine. I want to see if by tearing it down and cleaning will make it work again.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi,
Do not connect the power to the charge case. The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the case's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away.
You need to clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better.
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Here's a video that shows how to dis-assemble the buds and also the charge case, that will help. The charge case dis-assembly begins at approx. 8.00 minutes into the video.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
joms0140 さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 23
過去 30 日: 47
今までの合計 1,261
