Makes an intermittent sound when charging, lights flash, does not char
When I charge my JBL flip 6 it makes an intermittent sound and lights flash and cannot charge.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Sounds like a worn out battery
このアンサーは役に立ちましたか?
I bought it less than a year ago
@Victor Lolas If it's under a year old send it back under warranty.
Sounds like it's sending you a alert for water detected in the USB charging port.
It happens when the charging port is wet, it beeps because it’s a warning that you have a wet or moist charging port, just dry it out and make sure you read the safety book first, then dry it out. :)
このアンサーは役に立ちましたか?
過去 24時間: 24
過去 7 日: 229
過去 30 日: 1,176
今までの合計 5,681
