メインコンテンツにスキップ
The Samsung Galaxy A71 is an Android smartphone manufactured by Samsung Electronics as part of the Galaxy A series. It was released in January 2020. Versions: SM-A715F/DS, SM-A715F/DSN (Global), SM-A715F/DSM (Russia).
77回答 すべてを表示
My A 71 is frp locked help me please!
I have my A 71 frp locked so I have several problems to use it (forgot my google password so I can pass use it.What I have done? I have seen allmost videos on youtube but nothing works,I flashed anothe stock firmware but ls that is not working.The problem is that (I tryied with two different computers) that the handy in normal mode is not regnised only on download mode (on normal mode just recharge ).Atm is wIth android 11 I canT downgrad but I think I will be able to upgrade to android 12 but...that will sort out the problem or not? Is the frp locked the reason why no computers are able to detect on normal mode the handy?
tnx
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
flashing stock firmware won't remove frp it needs to be a combo file, the only other ways are use an unlocking box or paid service. heres a company that can remove it but you may lose the data thats saved on the phone unless you have already reset it. https://www.imeigurus.com/
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
@daniel
n to pay no thanks I found a few tutoial on hw t make cmb files/firmware but cant finde realy all files from stock firmware so I suspect it dipends on firmware country and so on The combo firmware are only for android 10 and I cant downgrade do u thnik that cable is not detected why is frp locked?
さんによる
@susan84 did you put the phone into download mode for flashing ?
さんによる
@tech_ni yes I did only on download mode the handy is detected from computer (that is why I was able to flash firmware with odin) On recovery mde instead adb not detect any device.Maybe ls my mistake to keep data s why I dident make the repartitiOn with din I can try to upgrade firmware and select repartition maybe will be that the solution ..I upgrade to android 12 nothng to do :/
PS:If i set repartitin din fail to flask
さんによる
@susan84 ok restart the phone and in emergency dialler dial *#0# to check if it gives a test menu
さんによる
*#0*# is for the test menu.
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Susan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 159
