Where is the TPM Chip on this Board?
To test the physical security of the TPM Chip against bus sniffing (LPC/SPI/etc) i was wondering where on the board the TPM chip is located and which model is used?
The IC is at UTPM and is a NPCT750LABYX_QFN32_5X5 TPM2.0UI9801.
See my previous comment for the last part of your question.
このアンサーは役に立ちましたか?
Do you have the location within the device too, like an image of the opened case instead of just an abstract drawing?
@btier no. that is what we need your pictures for.
I know this is old , but does anyone have the physical location of the TPM chip on this device? TY in advance.
@oakitoki if you post an image of your motherboard we can most likely point it out to you.
the TPM chip is on the back of the motherboard ;)
過去 24時間: 1
過去 7 日: 9
過去 30 日: 36
今までの合計 728
3 件のコメント
@btier attach some good pictures of your motherboard (both sides) with your question. That way we can see what you see and can probably point it out. iFixitでの質問に画像を追加する方法
How and why would you test it?
oldturkey03 さんによる
Hi @btier,
What is the model number of the motherboard?
What generation T14s is it, Gen 1, 2, 3?
Have you enabled TPM in BIOS > Security > Security chip?
jayeff さんによる
In this case a Gen 2.
Yes of course it is enabled but it doesn't mention the chip used and it also is not relevant to the physical security assessment.
mall さんによる
