メインコンテンツにスキップ
Where is the TPM Chip on this Board?
To test the physical security of the TPM Chip against bus sniffing (LPC/SPI/etc) i was wondering where on the board the TPM chip is located and which model is used?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
@btier attach some good pictures of your motherboard (both sides) with your question. That way we can see what you see and can probably point it out. iFixitでの質問に画像を追加する方法
How and why would you test it?
さんによる
Hi @btier,
What is the model number of the motherboard?
What generation T14s is it, Gen 1, 2, 3?
Have you enabled TPM in BIOS > Security > Security chip?
さんによる
In this case a Gen 2.
Yes of course it is enabled but it doesn't mention the chip used and it also is not relevant to the physical security assessment.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
The IC is at UTPM and is a NPCT750LABYX_QFN32_5X5 TPM2.0UI9801.
See my previous comment for the last part of your question.
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
Do you have the location within the device too, like an image of the opened case instead of just an abstract drawing?
さんによる
@btier no. that is what we need your pictures for.
さんによる
I know this is old , but does anyone have the physical location of the TPM chip on this device? TY in advance.
さんによる
@oakitoki if you post an image of your motherboard we can most likely point it out to you.
さんによる
the TPM chip is on the back of the motherboard ;)
さんによる
コメントを追加
回答を追加する
mall さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 39
今までの合計 1,016
