メインコンテンツにスキップ
モデル番号A1707。 2017年6月に発売されたこのMacBook Proは、最大3.8 GHzのTurbo Boost搭載の最大2.8 GHzクアッドコアIntel Core i7プロセッサーまでのKaby Lakeプロセッサーを搭載しています。
315回答 すべてを表示
MacBook not recognizing a battery is installed
I discarded the old battery from the MacBook as it was swollen. Installed an iFixIt battery, as I've done with other MacBooks, but it will not power on. I've checked, double checked, and rechecked my steps, but still no dice. The MacBook will power on and everything works when plugged in, although the fan spins at max speed, indicating no battery is recognized. When the MacBook isn't plugged in and I attempt to power it on, nothing happens. Even when we thought "Oh, just let it charge" and plugged it in for a bit.
When the MacBook is plugged in, it doesn't recognize a battery in System Preferences or the menu bar.
My first guess is the new iFixIt battery is faulty, but I could be missing something. Battery data ribbon cable was installed successfully, but it could just be a bad battery.
I'm stumped. Any tips?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
How about installing this app which allows you a better view of things CoconutBattery post a snapshot here for us to see.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
There are two possibilities. You could be right about the Ifixit battery being faulty, but it could also be that the battery connecter on the motherboard is faulty or broken in some way.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I figured the only other thing would be the connector. iFixIt is helping out with sending a replacement battery. If that doesn't work, then I'll make the grave call from there! Thanks!
さんによる
@jmic925 Happy to help :)
さんによる
コメントを追加
回答を追加する
Joshua Michael さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 55
