I cant play hulu on hp slate pro 21
i cant play hulu on hp slate pro 21
Update (10/08/2022)
its android 4.4 says incompatible. Disney says the same
So I know you can download the app (also called an APK) from 3rd party sites. I have an APK download you can try for Hulu that works with android 4.0. Just as an FYI, getting older apps to work can be a hit or miss because companies may not support the older app. You are more then welcome to try, and out of caution, I did check the APK here and it's safe to download.
Worst case, you'll have to use a browser to watch hulu on your android device.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 31
