Game won't load
I've tried playing my tiger woods 2004 game and it's says won't read disc, so I bought another one and tried it thinking cd was bad, that one says the same thing. Won't read disc, all my other games work in it.
If it’s not reading disks that usually means that your disk drive is at fault
Before we replace it I would try cleaning the laser as that can cause disks not to read(the laser is found where the disk is inserted and it looks like a little clear window,clean with isopropyl alcohol)
If that doesn’t work I would follow this guide to take it out and see if there is any dust or damage on the inside
PlayStation 2 Slimline 光学ドライブの交換
If it still isn’t working you will have to replace the disk drive
Here’s a link to the part
https://www.ebay.co.uk/itm/144644454924?...
The part is quite expensive so it might be worth looking for a donor console
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 5
過去 30 日: 13
今までの合計 325
