There is a piece of paper stuck in between the gap as I was cleaning
Is it a good idea to buy an ifix it and open the iphone in order to take out the piece of paper
Hi
I wouldn’t take it apart to get some paper out as it isn’t the easiest thing in the world for people who don’t have experience
What I would do is get some distilled water,fine tipped tweezers and a fine brush and try and get it out that way without causing damage(don’t use too much water just in case it gets inside)
You could also try tape or a vacuum cleaner
Or you could leave it as it could just come out on its own if you leave it long enough
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
Maybe try a half-assed opening procedure?
As in, take a suction cup like you were opening it but skip the Pentalobe screw removal and the heating of the case and just put some firm tension on the suction cup. That might expand the gap far enough that the paper will pull out easily.
@hellomacos, hard to say, there is a slight amount of expansion in the adhesive so I would think it would most likely be okay.
I could see that working aslong as they are careful:-)
過去 24時間: 0
過去 7 日: 4
過去 30 日: 8
今までの合計 59
