メインコンテンツにスキップ
2019年3月に発売。Mac Pro (Early 2009)は、IntelのNehalemアーキテクチャをAppleのプロフェッショナルデスクトップラインに搭載し、2010と2012のCPUアップデートを加えて、インテリアが再設計されたモデルです。
202回答 すべてを表示
Do you have a replacement for a north bridfge temperture sensor?
I'm getting error code: 4SNS/1/40000000:TNOD-117.114 on my 2010 Mac Pro this indicates an failure of the temperture sensor on the north bridge of the motherboard. Do you sell a replacement part for this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
4 件のコメント
@mayer - any ideas?
さんによる
I may have it but would need a photo and/or a part number.
さんによる
@thomasthumb - Can you give us a photo of the area and a tight one on the chip iFixitでの質問に画像を追加する方法
さんによる
I'm not even exactly sure where this is on the logic board but pretty sure it's on the processor tray of my 2010 Mac Pro 3.46 GHz 12-core. I'm not having problems with the computer I just bought it used on eBay and it passed all my live testing of ports, copying/compressing large files, and Geekbench processes but when I did a final test via the Apple Hardware Tool DVD disk I get these error codes that all point to the same issue each time I've tested it via the long extended AHT test protocol:
or this one:
4SNS/1/40000000:TNOD-117.364
or this one:
4SNS/1/40000000:TNOD-110.614
From what I understand from researching these error codes online they all point to a non functioning or partially functioning Temperture Sensor on the North Bridge of the Motherboard.
So I'm wondering if you guys sell this part for my Mac Pro and have any instructions on how to replace it?
Also, I'm wondering if this issue is really that big of a deal or a problem in real world terms?
THANK YOU!
さんによる
コメントを追加
1 件の回答
最も参考になった回答
@thomasthumb the sensor is part of your northbridge heatsink. The 4,1 and 5,1 and interchangeable so a 2008-2009 should fit. Check this guide out first Mac Pro Single CPU Northbridge Heatsink Repair Does not look like iFixit is selling it.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
But I have a 12-core 3.46 dual CPU tray Mac Pro 2010 and this is for a single CPU tray. Would then the repair be mostly exactly as shown here but done twice for my model?
Also, in real world testing of this machine I get no errors nor have any problems of any kind so is this non functioning sensor really a problem then in real world terms?
さんによる
@thomasthumb "I get no errors nor have any problems of any kind " if it aint broke dont fix it. If there are no issues, leave it alone. The Image is a 2010 and the guide is just that, a guide. Since you should still only have one Northbridge it should not change.
さんによる
コメントを追加
回答を追加する
Thomas さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 73
