メインコンテンツにスキップ
2015年9月25日に発売。モデルA1687/A1634。このデバイスの修理は前モデルと似ています。スクリュードライバーとこじ開けるツールが必要です。GSM もしくは CDMA。容量は16、64か128 GB。カラーはシルバー、ゴールド、スペースグレイ、ローズゴールド。
1041回答 すべてを表示
Image started to cut away and eventually would not display an image .
Image started to cut away and eventually would not display an image, but does power on/off. Does anyone know where to target the repair. I’m thinking it’s either the screen itself or the cable between the screen and connection or both. Does anyone have any opinions on this issue or have had the same issue and what repairs and parts did you buy?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi Mickeyz,
Having fixed a lot of phones in my day, I'd say there's a very high probability you need to replace the screen. The issue of whether it's the screen or the cable connecting the screen is moot because the flex cable is integrated into the screen and can't be replaced separately. And since the connector to the motherboard is locked down under a metal cover, it's unlikely that any kind of spontaneous damage could occur without catastrophic damage to the screen itself.
Since this is an older model iPhone, the prices have dropped considerably. The first ones to come up on a search on Amazon were only about $25 USD, which is pretty inexpensive for that repair.
Amazon.com: Black for iPhone 6S Plus 5.5 Inch LCD Screen Replacement Full Digitizer Assembly Frame Set Front Glass 3D Touch Display Required Tool Kit : Cell Phones & Accessories
Of course, if you don't mind paying a bit more and want to support iFixit, you can always purchase the screen here. You can optionally buy it with a "Fix Kit" that has all the tools needed to do the repair.
iPhone 6s Plus Screen: LCD and Digitizer Repair Kit *20% OFF*
Here's the guide to replacing the screen that you'll need. Just follow the instructions from beginning to end and you'll be all set.
iPhone 6s Plus Screen Replacement - iFixit Repair Guide
Good luck with your repair; let us know how it goes!
iPhone 6s Plus Screenの画像
製品
$64.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Mickeyz さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 4
今までの合計 17
