My MSI GF63thin 9rcx heating issue
My MSI GF63 thin 9rcx cross 95 degree while playing games can any one help me to fix this problem
Hi
Laptops tend to heat up like this when playing games due to them not having massive heat sinks,however there are somethings we can do to help the issue
The first thing you should do is open it up and clean away any dust with a soft anti static brush
After that you are going to want to replace the thermal paste on the cpu and gpu if it has one
Here’s guide to help
https://m.youtube.com/watch?v=neNLB_F7FH...
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
DO NOT try to brush out dust. Use compressed air to blow it out.
I own the same thing. It is normal in stock condition for CPU temps to go upto 95 degrees. For me undervolting the CPU and GPU made the world of difference. Also investigate your cooling system. It might have dust build up.
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 23
過去 30 日: 63
今までの合計 473
