Rear Camera Bezel Replacement
I have a chip in the bezel of my rear camera. Everything I see is in regards to replacing the whole camera lens. Has anyone just replaced the bezel?
@nicholas__kerns, a third possibility - the one I thought Kaiya was talking about - is the raised glass area surrounding all three of the camera lenses, marked in orange on your picture. I honestly haven't looked into it to any great degree, but I'm pretty sure the only way to replace that square is to swap out the entire midframe, which is a major job; possibly the hardest repair possible on an iPhone that doesn't involve microsoldering.
I wanted to just comment on your post, Nicholas, but there's no way to post a photo from a comment.
このアンサーは役に立ちましたか?
Yes, Jerry is correct, to replace this orange section, it would take either replacing the whole back glass or entire frame with new back. This is extremely difficult.
Welp, @Kaiya Sjoholm, looks like @nicholas__kerns and I are in agreement; unless the chip is on one of the three camera lenses, which can be replaced, fixing any other damage will require either rear glass replacement or replacing the entire midframe, both of which are major repair jobs.
Ultimately, it's probably not worth it unless you have money to burn or feel like tackling a very difficult repair.
I have attached an image to help identify your problem.
I hope this helps you!
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 7
過去 30 日: 37
今までの合計 1,526
