メインコンテンツにスキップ
モデル番号A1707。 2017年6月に発売されたこのMacBook Proは、最大3.8 GHzのTurbo Boost搭載の最大2.8 GHzクアッドコアIntel Core i7プロセッサーまでのKaby Lakeプロセッサーを搭載しています。
327回答 すべてを表示
Replaced display, works in boot screens, but not in OS X
I recently followed the excellent guide on replacing the screen on my 2017 Retina Macbook Pro (A1707). When I powered the computer back on, I got a normal boot screen, but once OS X starts booting from the firmware, the display goes dark. I plugged in a monitor, and the display isn't present in OS X. It works in firmware, though!
Running diagnostics, I get an error: Reference Code VFD003 - there may be an issue with the display.
I installed a brand new display that I bought on eBay. Has anyone ever seen this before? SMC and PRAM have been reset.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Sounds like the T-CON board which is that circuit board that is part of the display assembly is defective. Basically you need to exchange the display assembly as this one is bad.
Your system offers different scan rates:
2880 by 1800 pixels (Retina); scaled resolutions: 1920 by 1200, 1680 by 1050, 1280 by 800, and 1024 by 640 pixels
The systems firmware boots up under 1280 by 800, so you see the Apple icon and the loading thermometer, at the end of the loading your system will then switch to the higher retina scan rate 2880 by 1800. At this point the timing logic within the T-CON jumps to a higher rate which it can't do as the logic is bad.
このアンサーは役に立ちましたか?
スコア 2
13 件のコメント:
Booting in verbose mode shows kernel log messages at the full 2880x1800 pixels, so I don't think it's that. Thanks for the tip, though.
さんによる
@marcinr - I'm assuming you are seeing this either via an external monitor or the internal display.
It's a bit confusing as the OS's video driver (kext) is loaded at that point so it will show 2880x1800. What is loaded before is the firmware video driver is 1280 by 800 and within verbose mode the screen is in text mode 1280 by 800 even with the driver could offer 2880x1800.
You could also see the full 2880x1800 if you had a 4k display plugged in externally. But again that's not via the internal displays logic.
さんによる
Are you sure about that? The text is miniscule, and I need to use a magnifying glass to see the individual bitmap fonts. I'll try to arrange an exchange of this screen, but... ugh, ebay. Thanks for the advice.
さんによる
@marcinr - What does an external display show you?
さんによる
During firmware portion of boot, external display doesn't show anything. Once firmware hands off to OS X, internal display turns off and external display runs at its own resolution.
さんによる
8件以上のコメントを表示
コメントを追加
So I have a possible solution
It could be the flex ribbon cable giving you issues. If you can, remove the screen from the logic board socket and spray some compressed air and plug it back in (Firmly)
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Sadly, that didn't help. It's some kind of electrical incompatibility. I wonder if the seller sent me the correct version of the screen.
さんによる
コメントを追加
回答を追加する
marcinr さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 4
今までの合計 134
