Will I get an on and off logo if taptic engine cable is broken?
I replace the battery and accidentally break the taptic engine cable. Will that be the cause of Apple logo just turning on and off?
Update (09/16/2022)
I tried putting back the old battery and still showing the same problem, tried reseating all.the cable i took.before and same.thing happen. I tried repair recovery same thing, haven't done the full recovery or dfu reset.
Update (09/17/2022)
Seems there's a hope in unplugging the front camera and it dhows press home button to recover, but my home button is not responding. Is there a connection between home button and the damaged taptic engine?
2 件のコメント
With just the update and unplugging the front camera the phone is trying to boot but I got stuck in press home button to recover but the problem is my home button not working too. I replace my Taptic Engine because cable was damaged and do the update still the same boot loop happens . With the front camera disconnected after the update it shows press home button to recover which is the same as before. I ask my son if it’s okay to wipe out the games he has on the phone to do the restore option and of course it’s a yes. With everything connected I’m still getting the boot loop and with the front camera disconnected that’s the time the phone boots normally. There’s a tutorial too in you tube when your home button is not working. My sons phone is now working and my next thing to do there is to replace the home button and front camera cable. Hope this helps.
Nielson Meracap さんによる
@daddybuddy I am posting an edited/updated response to your question, I just tend to put everything in my main answer for better visibility to future people who may have this issue. So I wanted to make sure you get notified of that.
Alisha C さんによる
