What is the Battery volume?
I want to compare with S7 battery volume to see if the batt really is another tech
Hi, the dimensions of the battery are approximately: 4.7 x 29.2 x 25.4 mm
You can also check out Apple Watch Ultra Battery Replacement for more info.
このアンサーは役に立ちましたか?
Great, thank you! Same efficiency!
@Albert Cor - Energy density is more a factor of chemistry for the given physical space (volume).
Right now we are at a plateau, the current Lithium Ion battery chemistry is the densest we have.
According to the iFixit page for the Apple Watch Ultra, it is a 542 mAh / 2.07 Wh battery
このアンサーは役に立ちましたか?
I wasn't asking about capacity, but volume. Are they able to put more capacity in less volume?
What do you mean by volume? Like physical volume?
@jmehnert Yes, thank you!
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 547
