Why is screen flashing the apple logo while calibrating a new battery
Why is screen flashing apple log while new battery is charging?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Since you just replaced the battery, you could open the phone up and try to disconnect and reconnect the battery. On iPhones if the battery isn't plugged in, and you plug it in to power, it will just flash the Apple logo. Otherwise you may have a bad battery that is so low on charge the phone thinks the battery is unplugged therefore is just flashing the Apple logo. This would fix this issue assuming that nothing else was damaged during the battery replacement process.
このアンサーは役に立ちましたか?
Thanks so much, this really helped
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 2,361
