MacBook not turning on, black screen, fan turning at full speed
My macbook 13" 2015 A1466 is not turning on, the fan is running at full speed and I have a black screen.
Any help on the step to find and fix the origin of the problem would be highly appreciated.
So far I've tried to reset SMC but it did not work.
この質問は役に立ちましたか?
4 件のコメント
What happens when you try to enter into the onboard diagnostics? Restart your system and press the D key
Reference: Mac startup key combinations
Dan さんによる
Nothing more happens, if I start using D and the computer plugged the behavior is the same... Note : if not plugged, the computer often stops a few seconds after the start.
Orion さんによる
@orion3146 does the boot chime sound come up? Could be a bad thermal sensor. Disconnect your fan and try to power your MBA up. See if that changes the behavior. Don't run it without fan but it is okay to see if it changes the behavior.
oldturkey03 さんによる
@oldturkey03 I have tried what you mention : the MBA powers up with a black screen. I turned it off shortly after to avoid damage.
The boot chime is not audible.
Orion さんによる
