メインコンテンツにスキップ
Microsoftの次世代4kゲームコンソールのXbox Series Xです。Xbox Series Xは対応コンソールと共に2020年11月10日に発売されました。
67回答 すべてを表示
Why do I have an extra screw?
I followed the guide from How Fixit and even checked the guide here. I did the guide twice and for some reason, I have one 8.8mm screw and I can’t seem to figure out where it’s from. All the screws are in place according to the guides. Even when disassembling from start to finish and reassembling it back, I still can’t figure out where this one extra screw came from. Anyone have any idea where I should look?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi @kain05
Looking at the ifixit Xbox Series X マザーボードとヒートシンクアセンブリの交換 guide, there are 15 x 8.8mm screws.
If you open the guide and then do a search function (in Windows - Control key + f key then type 8.8 in the search box) it gives the location of the screws in the guide.
Hopefully you may find where the extra one goes.
このアンサーは役に立ちましたか?
スコア 2
8 件のコメント:
Thanks for the fast reply. But all the 8.8 screws that show up during the search on that page, have already been put in the same places. Is there other 8.8 mm screws on the Series X? Maybe one came loose somewhere else and I didn’t notice.
さんによる
@kain05 there are 22 x 8.8mm screws shown in the Southbridge shield guide for the console.
Obviously some are the same but that means 7 more screws to check
さんによる
Is that the only other guide with 8.8mm screws? If there is another guide with 8.8mm screws, post it. I don’t mind checking to make sure. I mean the console is working as it did before I disassembled it so. Plus, the more I do it, eventually I won’t even need the guide anymore. Also, thanks for the help.
さんによる
@kain05
If you click on the device icon to the right of your question at the top of this page it will open the page with all the guides for the device.
Alternatively, here it is
I went for the ones which I thought would require the most dis-assembly to get at but I didn't look at all of them
Cheers
さんによる
Thanks @jayeff
I appreciate the help. I’ll search within the pages for 8.8mm screws. Hopefully I’ll find out where this mystery screw came from lol. When I do, I’ll post it. Thanks again, I appreciate it.
さんによる
3件以上のコメントを表示
コメントを追加
回答を追加する
Kane さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 9
今までの合計 195
