メインコンテンツにスキップ
LG "6 Motion Direct Drive" washing machine released around 2017. Product code FH4G6TDYW2.ABWQWFS.
15回答 すべてを表示
Why washing maching keep noising while spinning?
My Lg washing machine keeps noise while spinning. It won't make any noise during washing. Just only on drying the clothes.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
LG washers beep at the end of each cycle to indicate that they are done, and can typically be silenced by pressing the beep button on the front. Other reasons for a washing machine to beep include running out of water or if something has been jammed into it.
A front load washer is a machine that washes clothes based on a programmed cycle. The timer on the machine may have been set to time out and cause an alarm. This is a safety feature that has been put in place to ensure that people don’t forget to turn off the washer. If the timer hasn’t been set, it may be due to a power outage or circuit failure.
If you don’t want your washer to have a beeping party, it’s crucial to know why your washer keeps beeping. Only then you’ll be able to fix it.
To fix your washer you can try the following things (don’t call the service provider just yet):
* Check if your machine is getting water
* Recheck if the lid is properly closed
* Redistribute the load
* Make sure your machine is properly balanced on the surface
* Check if the water is properly drained (if it’s close to spinning)
Now, let’s get into the reasons why your washer’s beeping at you.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I lg turbo washing machine noise while spin I think something as been stuck in how to clean it remove inside like coin or other think
さんによる
コメントを追加
回答を追加する
Kemaji さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 16
今までの合計 4,625
