メインコンテンツにスキップ
1998年に発売された任天堂ゲームボーイのカラー版です。このデバイスの修理は難しくありません。
Why there is no sound from the speaker and headphone jack
there is no sound coming through speaker and headphone jack, just the hiss sound
at first i tried cleaning with isopropyl 99%, nothing happens
i have already replaced the speaker with a new one still does not fix
i also re-solder the connection on volume wheel, still no sound
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Strange? Have you checked, reset the device incase it is a setting? I know it sounds a simple idea and you may have already done. However, I for one forget check the small things
さんによる
コメントを追加
2件の回答
最も参考になった回答
Hi @unikkoijo
Here's an image of the audio section from the schematics for the game console that may help.
(click on image)
Given that there's no audio heard in either the headphones or the speaker it may be that the U3 audio amp has failed.
You could always check if it has only partially failed by checking if there is audio heard by disconnecting one side of C14 from the board and placing a speaker between U3/3 and earth. If there is then it could be that C14 is short circuit or that C38 is open circuit.
The other check is placing a speaker between U3/12 and earth and U3/15 and earth and check for audio in case there is a audio for the L & R headphone speakers.
If there is no audio heard at all then either U3 has failed or its not getting an input on U3/7 & 8 for some reason.
Make sure that there is voltage on U3/4 & 14 (VCC) and also U3/5 (VDD5)
Hopefully a start
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
@unikkoijo double check your headphone jack. If it has failed it may just block the sound. Also, check the volume potentiometer. Make sure it is functioning. After that it is a component in the audio circuit that can have failed. Check the easy stuff first.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
i tried replacing the volume potentiometer, still no sound both headphone and speaker
さんによる
@unikkoijo Did you ever get this fixed by any chance?
さんによる
コメントを追加
回答を追加する
Kenneth Co さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 33
今までの合計 1,349
