メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
A1370 MacBook Air will not boot with/without battery
I have a Late 2010 11-inch MacBook Air that my aunt gave me to repair and I am having difficulty seeing if it will boot up or not. I found out that the battery has swollen in the machine so I had threw it out to prevent a fire or explosion. After that, I plugged in the machine to see if it would boot then but it still won't. I tried resetting the SMC and also pressing down the power button, then plugging in the power adapter, still holding down the power button. Nothing worked. Is there something wrong with the logic board or I/O board? After plugging in my 85 watt power adapter, it just shows a green light continuously. Sometimes it will show a dim green light. Please help, thanks
Here are picture of the boards
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
First a 85Watt unit is too much for your system you need a 45W MagSafe 2 Power Adapter for MacBook Air. It also sounds like you have a deeper issue with either the MacBook Air 11" (Late 2010) I/O Board or within the charging logic in the main logic board.
For now lets get a good set of pictures of the I/O board so we can check the contacts and look for corrosion iFixitでの質問に画像を追加する方法. Follow this guide MacBook Air 11" Late 2010 I/Oボード交換
Replace an I/O board compatible with the Late 2010 model MacBook Air 11 inch laptop. Fix problems with charging, audio, and data connections. Includes the MagSafe power, USB, and audio ports.の画像
製品
$29.99
MacBook Air 11" Late 2010 I/Oボードの画像
ガイド
難易度:
中レベル
iFixitの画像
ガイド
難易度:
とても簡単
2 - 5 minutes
このアンサーは役に立ちましたか?
スコア 2
12 件のコメント:
Can it still work with a 85 watt power adapter or do I have to buy a 45 watt one?
さんによる
I added the pictures of my I/O and logic boards
さんによる
@mahzak09 - Almost! You'll need to take it out and take the other side and the MagSafe connector so we can check it as well.
さんによる
Added bottom of I/O board
さんによる
@mahzak09 - One more! the MagSafe connector face where the cord connects
さんによる
7件以上のコメントを表示
コメントを追加
Well this video might help you in fixing: Macbook Air 13 2012-2017 , Will start without battery but wont start with it
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
MZQK さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 28
今までの合計 640
