メインコンテンツにスキップ
The Maxima was redesigned for the 2009 model year and made its debut at the 2008 New York International Auto Show.
20回答 すべてを表示
OBD giving 1778 engine light code
My car is accelerating slow after coming to stops. The engine light is giving me a 1778 code and after some research I learned that I needed to replace the stepper motor. After replacing the stepper my issues were still there. I tried replacing the Mass air flow sensor and the problem is still there as well. What else could I try?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Try searching for Nissan Maxima forums. Owners share info freely and may help you. If you have a cvt, this may be a known problem.
さんによる
コメントを追加
1 件の回答
After installing the parts you have to reset the error codes. You can wait for few miles to detect the issue has been solved and the error code will gone. It is also possible you have some more parts has fault. Please contact any expert technician locally to examine the issue.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Quincy Williams さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 115
