My screen is popping up
I'm just gonna assume that its my screen popping up right below the volume button, it's little bit but it's enough for me to see a yellow/orange light thing.
My screen was coming off at the bottom and sliding down. I keep it in a stand all the time. Took it to the repair shop. They warmed up the screen and adhesive, moved it back in place, clamped it a few minutes to let it cool, and done. It had just gotten warm enough to let the adhesive loose, and it was falling off. All good now!
Now I lay it flat while charging.
このアンサーは役に立ちましたか?
I used one of those pop up buttons on back of my tablet pickEd it up one day and came unglued from using it is see a light in it home button moves around not working nor back button.
Swollen battery. Open it up to check. Yellow light thing is pressure on the back of the screen. If you’re not comfortable doing it yourself take it to a shop to have it checked.
このアンサーは役に立ちましたか?
NOTE - this can be a serious issue. I would stop using/charging the phone NOW. Either fix or trash it. Swollen batteries are dangerous.
過去 24時間: 6
過去 7 日: 29
過去 30 日: 158
今までの合計 2,282
