メインコンテンツにスキップ
2015年3月のアップデートではAppleの11インチMacBook Airは第5世代Intel Core i5またはi7プロセッサーを特徴としており、これによりわずかな性能とバッテリーライフの向上がされました。
141回答 すべてを表示
iFixit Battery received has a protection film all over it.
Hi ,
I have received a new battery from iFixit today for my macbook air early 2015.Upon opening the box , i have noticed that there is a protection film ALL OVER the battery and not like in the guide description NOTE:
Note: If there is a thin plastic film on your replacement battery, do not attempt to remove it. It is glued on and protects the battery pack while it is inside the MacBook.
This is not only over the battery cells but all over the battery...
Should I remove it for installation or keep it?
Many thanks in advance.
Picture attached for reference.
Update (08/16/2022)
I am just thinking that the plastic might affect the battery , as this is my second batter from iFixit and the first one, did not have anything like this...
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
3件の回答
ベストアンサー
Hey all!
I got some information from iFixit EU side this morning:
Thank you for your message and the purchase from our Store.
The plastic film seen on your picture is supposed to be removed.
Should you have any other questions, please feel free to ask.
Kind regards,
Leon (iFixit EU Team)
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
最も参考になった回答
@xdrqgol leave it on and install your battery as shown in the guide
このアンサーは役に立ちましたか?
スコア 3
8 件のコメント:
First time you said: you will have to remove that to install your battery. If you do not then the glue strips would not work. :D I am skeptical ...
さんによる
Yes that is because I just did a Macbook Pro and it had the glue strips covered and a protective cover over that. A case of mistaken identity not realizing yours was a MBA.
さんによる
I am just thinking that the plastic might affect the battery , as this is my second battery from iFixit and the first one, did not have anything like this...But also the holes matching in the protective film , which makes it available for you to install it with it ON, is also something that makes me think..
So I would need to know what to do from someone who had a similar battery from iFixit ..
さんによる
I understand but if it would just be a removable plastic it would not have the holes in it and your battery is secured by screws not glue strips. Who knows why the other one did not have it but I would go ahead and follow the guide
さんによる
@oldturkey03 yes that makes me think about it. thanks
さんによる
3件以上のコメントを表示
コメントを追加
I have an answer @xdrqgol! With this particular model of battery it's up to you. You can leave it in and it won't melt or you can remove it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Rasmunson さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 30
今までの合計 871
