Which bit do I use to remove back?
Looking for the correct bit to open my Air M2. P5 seems loose when I try to use it.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi
I believe it is a p5 that is used
If a p5 doesn’t feel tight enough try a p6
If it’s too big try a p4
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
P5 is correct. Ordered a new P5 bit and it worked great. Also purchased the magnetic project mat and highly recommend it!
I find that anything magnetic is handy:-)
A Penalope 5 screw bit probubally because apple uses the P5 bit on all MacBook pros post 2012, and airs post 2018. I do with they would change it.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 15
今までの合計 708
1件のコメント
Example
https://www.ebay.co.uk/itm/272489549449?...
[deleted] さんによる
