gray and green lines
it show gray and green how to i fix it
この質問は役に立ちましたか?
Hi Joe,
The best way to troubleshoot your issue is to connect the iBook to an external monitor and check if you have the same issue on the external. If so then your graphic chip is failing and it's time for a new machine. If the image is good on the external monitor then you need to replace the LCD panel or the LVDS (video) cable. You could begin by trying a PMU reset and a PRAM reset.
このアンサーは役に立ちましたか?
+ Ralph
is going - there's a possibility of lengthening the life with a shim on the GPU or the fire trick... start saving for a new laptop.
If this answer is acceptable please remember to return and mark it.
Good Luck,
N.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 816
