Why is my phone half screen only when it gets light
If your phone is cracked, chipped or broken then it's a obvious one if none of the problem is there then try the following.
このアンサーは役に立ちましたか?
After it was hitten on the middle part of the screen the bottom half of the screen only shows only white color when its on until i flash a beam of light In the sensor part
You’ve answered your question. Hitting the screen on the middle has damaged it. You need a new screen.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 71
