Is the battery in the series 6 44mm the same as SE 44mm?
I cant find a battery for the series 6 44mm
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The two batteries (6 and SE) have different part numbers, so it's not safe to assume one will work in place of the other. The one example I found on eBay shows a mAh rating of 303.8 for the series 6 battery, while the SE battery reads 2.96 mAh. The connectors look physically similar, but I can't say with any certainty whether it will plug in or not.
Here's a link to the eBay battery; no telling how long the link will be good for though
Li-ion Battery A2327 303.8 mAh For Apple Watch Series 6 44MM (GPS Version)
このアンサーは役に立ちましたか?
I found the battery as well as other parts at www.injuredgadgets.com. Thanks all.
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 96
2 件のコメント
Your watch may still be covered under warranty! Sept 2021 is the when Apple switched over to the Series 7 so you might have a slim window to get it replaced for free! My own watch battery failed in Feb and I was able to get it replaced for free under warranty! Some countries have a two year warranty law as well.
Dan さんによる
That was the first thing i checked. Out of warranty. So I think at this point I'm going to buy a new battery and attempt the replacement.
Justin4Pack さんによる
