メインコンテンツにスキップ
2014年4月のアップデートによりアップルの13インチMacBook Airはデュアルコアi5またはi7プロセッサーの更新とわずかなバッテリー性能の向上がされました。
316回答 すべてを表示
No longer working after I messed with the I/O cable after disassembly
For full disclosure, I got a Macbook Air that was water damaged years ago. Got it 2 weeks ago and it works great with the charger connected to it as it got a bad battery inside that I was able to remove after and will be replacing it.
So I disassembled it again, to clean the water stain for just a little and one of the components I just removed was the I/O cable to check and inspect it and snap back into place. I closed it all up again and connected the charger and no light was showing. Then I got this weird behavior, it turned on but no light on the charger and the screen and backlight keyboard open and close in like a cycle of a few seconds then it turned off again.
Is there something wrong with the I/O cable that I messed with?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
You've hit a common issue with this series as the I/O board also holds both the MagSafe connector and the Hall sensor which detects the opening and closing of the display lid by the magnet that is holds and becomes close to the sensor within the I/O board (marked in Yellow] I often need to replace them from liquid damage.
At this point it would be wise just replacing the I/O board MacBook Air 13" (Mid 2013-2017) I/O Board
MacBook Air 13" (Mid 2013-2017) I/O Boardの画像
製品
$79.99
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Seems like it, because I would see a faint apple logo on the screen when I connected the charger (still no light on it) then it would do the cycle of screen on and off when I got to the login screen
Is it wise to replace the I/O cable too?
I'm glad that the logic board was not the issue.
Thank you so much Dan!
さんによる
@toby25panaga - Sure that makes sense while you replace the I/O board
さんによる
コメントを追加
回答を追加する
toby25panaga さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 18
今までの合計 55
