メインコンテンツにスキップ
iPhoneを自分で修理するために必要なものはすべて揃っています!最新のiPhone 15から、2007年に発売された初代iPhone 2Gまで、iFixitにはすべてのiPhoneに対応する無料の修理ガイドと分解情報があります。
36491回答 すべてを表示
締切られた回答
How do I reconnect the motherboard ribbon cables?
I have watched and read many descriptions of how to disassemble a 1st gen iphone, but have found none that show me how to reassemble one.
I am having great difficulty reconnecting the ribbon cables beneath the motherboard. Is there a special tool for this? Thanks much.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
With your finger ? If you disconnected it by prying it with a spudger, just put it back by pressing the connector to its socket, but verify is well lined up.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
M specific issue is with the digitizer ribbon once the other three are already connected. I can't get my finger in there.
さんによる
My fingers are unable to connect any of the Logic Board Connectors except for the Back Case Flex Ribbon. The rest I lay the Logic Board carefully in its position, then I slightlhy lift the board up and using a thin probe push them into place basically upside down, sometimes even just pushing the board back down on the connector while the probe guides everything. Its a bit of trial and error and carefully inspecting underneath, because you don't want to leave one undone that you connected earlier.
さんによる
I see, I've never had an iPhone 1G in hands, but I read the guide more carefully. What I'll do after replacing the one step 25 is putting the others back using the spudger as a lift, it must be coarse but I don't see any other way to do it. Once again I can't help much as I've never done it with an iPhone 1G
さんによる
it's a very tricky setup but the only other tool to use here is a pair of tweezers or forceps. I nearly pulled my hair out trying to do this but managed with just fingers..
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 10
今までの合計 3,386
