メインコンテンツにスキップ
Scientific Casio Calculator released August 2000. Identified by the model name FX-115MS
7回答 すべてを表示
How do I fix my transparent solar calculator
I know it sounds fake but those things are real, i couldnt find any pictures of it in the options and mine is kinda broken.
6 works but the other keys don't, i went outside coz i figured that maybe it needed sunlight but it still didnt work. What do i do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Tried disassembling it and cleaning debris collecting between the membrane keypads and circuit board? The carbon film on membrane pads may be worn down and unable to connect circuit lines when pressed onto the board. Other issues may be worn out electronics or damage wiring. If unable to resurrect this calculator then its time to replace it.
さんによる
コメントを追加
1 件の回答
The solar cell charges a battery, they don't last forever so I d open it and see if I could find a replacement battery for it. If you perhaps dropped it there could be just a loose connection so look for anything obvious. Not your device but possibly helpful answer referencing a solar powered calculator repair is here. Good luck!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
TheGuyWhoAsked さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 24
今までの合計 211
