メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Scientific calculator by Casio. Widely used by students world-wide due to its great quality for the low price.
How do I fix my calculator that only runs on solar power?
My Casio fx-991ES PLUS was dropped and now the display does not light up unless it is under a light source. It has a mini solar panel which I assume it using for power and it has new batteries in it but they do not seem to work. Is there something I can do to fix it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 7
1件のコメント
I replaced mt calculators
さんによる
コメントを追加
2件の回答
ベストアンサー
@madrthanevr could simply be an issue of torn wires/ connectors or something more sinister like an issue with the power management IC on your PCB. We’d need to see what is going on inside your calculator iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
Thanks @oldturkey03 there was just a disconnected wire. Probably should have checked beforehand. Much appreciated!
さんによる
My casio MJ-12D is not working after putting in sunlight.....what should i do for this??
さんによる
@madrthanevr how did you check the wiring? I have a similar problem
さんによる
コメントを追加
Casio can replace the broken screen, they will give you a price before they do the repair, by the time you add shipping to them and shipping back to you, you will be better off just buying a new calculator and keeping this one for spare parts for the next person who wants to buy a motherboard.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
MadRthanevr さん、ありがとうございました!
統計データ:
過去 24時間: 9
過去 7 日: 38
過去 30 日: 145
今までの合計 27,088
