メインコンテンツにスキップ
A2116 / 2019 / 3.6 GHz quad-core i3, 3.0 GHz 6-core i5, or 3.2 GHz 6-core i7 プロセッサ、発売日は2019年3月19日です。
78回答 すべてを表示
Can I replace the Fusion Hard drive with an SSD on a 2019 iMac? and...
Will it cause any issues with the way the existing Fusion flash blade recognises or communicates with the new SSD?
Is it necessary I buy and connect a Thermal Sensor?
Can I buy any SSD? or are there some which cause conflicts?
I appreciate any help.
Thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
The blade SSD is used as a cache drive to the 2.5" HDD when the two are setup as a Fusion Drive set.
When you remove the HDD replacing it with a SSD you will sever the Fusion Drive so the Blade SSD will just sit unused. The first versions of Fusion Drive used a 1TB HDD and had a 32 GB SSD for the cache drive, after August 4 it had a 256 GB SSD.
If you have the larger blade SSD I would recommend reformatting making it the OS boot drive as the PCIe/NVMe interface is faster than the SATA III (6.0 Gb/s). Sadly the small 32 GB drive is not large enough to do much of anything.
Here's the guide you'll need to follow to replace the HDD: iMac Intel 21.5インチ Retina 4K Display 2019 ハードドライブの交換
If you can I would upgrade the blade SSD to something larger 256 is a good size for writing and simple web use with the macOS on it. Going with 512 or larger offers a lot performance! Here's the guide for it iMac Intel 21.5" Retina 4K Display (2017)ブレードSSDの交換
Otherwise don't worry about the blade SSD, just let it sit unused if you go with the 2.5" SSD.
iMac Intel 21.5" Retina 4K Display (2017) ブレードSSDの画像
ガイド
難易度:
中レベル
1 - 3 hours
iMac Intel 21.5" Retina 4K Display 2019 ハードドライブの画像
ガイド
難易度:
中レベル
30 minutes - 1 hour
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
James Rice さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 192
