メインコンテンツにスキップ
Mac Proとして知られるデスクトップMacシリーズの2013年版新モデルです。
117回答 すべてを表示
2013 Mac Pro randomly powers off
Good afternoon everyone..
I recently picked up a nicely configured late 2013 Mac Pro that is having an issue I can't seem to resolve.
Machine configuration is as follows:
8 core/16 thread Xeon processor
64 GB ECC RAM
1 TB SSD
2 AMD FirePro D500 GPUs with 3 GB vRAM each
4 USB 3 ports
6 Thunderbolt 2 ports
2 GB Ethernet ports
Problem is it'll be running along just fine, and then for no apparent reason, it will just power off. If I hit the power button, it will come back up like normal and run fine. Sometimes it will go several days without doing this, and other times it will do it a couple of times a day. Do you have any idea what may be wrong? Any help or suggestions are greatly appreciated.
Thanks, and have a great weekend.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
There are two possibilities. The first is the system is just going into sleep mode. A quick hit to the keyboard, trackpad, mouse or power button should wake the system (not restart).
If the system restarts then you likely hit a crash event. Make sure your apps are up to date for your version of macOS.
You may need to review the crash files Tutorial: An introduction to reading Mac OS X crash reports
You might want to run the onboard diagnostics as well. Restart your system and press the D key to enter
Reference: Mac startup key combinations
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Good afternoon,
Thank you for your response. It is definitely powering off, and not just going to sleep. To get it to come pack up, I have to press the power button. I've run Apple's diagnostics, and it reports everything is fine. I'm going through apps now to make sure they are all up to date.
さんによる
コメントを追加
回答を追加する
Joe Alberti さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 46
