I dumped my oculus quest in water
I was playing gorilla tag and my oculus quest flew of my head and landed into my dogs water bowl. Can someone help me fix it.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the headset's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your headset and then remove the battery as soon as possible from the headset to minimize any further damage.
Then you need to dis-assemble the rest of the headset and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the headset might possibly work correctly again.
Here is a link to a teardown video that may help.
If this process seems too daunting, take your headset to a reputable, professional electronics repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 8
過去 30 日: 60
今までの合計 1,614
