Thumbstick drifting in neutral position of it
Left hand thumbstick is in neutral position but game character moves on.
You have to push and pull the thumbstick in different directions to stop the drifting.
How to fix that?
For those looking for a solution.
Look on reddit guide:
https://www.reddit.com/r/ValveIndex/comm...
This is the replacement part:
このアンサーは役に立ちましたか?
Hello!
Sadly i don't know how is this controller really build, but i guess it's the same problem like in xbox controller. Analog inside just got broken. If you still have guarantee just send it back. If not, you need to replace it with new one. It's called 'FJ06K-S' probably. If you have soldering iron and some skills in soldering go ahead.
Good luck
このアンサーは役に立ちましたか?
Ive dug around a lot in my index controllers because of drift and the capacitive sensor on top, as far as I can tell there aren't any official replacements online, but the joysticks just use 2 through hole potentiometers so for drift, contact cleaner might work. You can probably follow the instructions on replacing the strap to get the top open, but if you are under warranty, because of the limited part availability I would just get it replaced until they stop giving you replacements.
このアンサーは役に立ちましたか?
過去 24時間: 20
過去 7 日: 89
過去 30 日: 323
今までの合計 8,395
